Date/Time: Sat, 27 Apr 2024 17:23:21 +0000
Danali Exchange Data Feed with StoneX account
View Count: 71
[2024-03-13 22:46:26] |
DP - Posts: 4 |
Hello, I have a StoneX brokerage account and want to convert my Sierra Chart (SC) trial account to a live (paid) account using the Danali Exchange Data Feed. Can I do this while still keeping my StoneX Account or do I need to sign up with another broker (e.g. Stage 5)? If so, how? Note: It is OK if I need to execute trades separately with StoneX (not from SC). |
[2024-03-14 14:36:02] |
We do not work with StoneX, so if you are wanting data for the CME Group, then you will need to have an account with a different broker that we do connect with in order to qualify for the non-professional requirement from the CME Group. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have another account that will qualify for this, then we recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement If you need data for another exchange - EUREX, CFE, or U.S. Equities, then these do not require having a brokerage account in order to get the data. To setup the data for the CME Group, follow these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* To setup data for any of the other exchanges on our Denali Exchange Data Feed, then follow these instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
