Date/Time: Thu, 19 Sep 2024 16:14:00 +0000
Managing old data
View Count: 928
[2014-08-09 04:52:07] |
User96105 - Posts: 113 |
I have quite a few old/unused chartbooks in the data folder. Can I move these .cht files out into a new "Dataold" folder? Do I need to move associated other file types (which I would prefer to do) and if so how do I identify them?
[2014-08-14 09:15:45] |
Yes, you can move the Chartbook files out of the data folder. You can also move the chart data files. More information about chart data files can be found here: https://www.sierrachart.com/index.php?page=doc/doc_ChartDataFiles.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
