Date/Time: Sun, 28 Apr 2024 16:49:42 +0000
Chart problem with time frame 60min od Dow Jones index
View Count: 55
[2024-03-13 18:31:25] |
User718241 - Posts: 1 |
Hello, I sent in the attachment princ screen with the problem when I change to 60 minutes chart on this instrument it shows me 1 hour chart from xx:15 but it should show me a candle for a whole hour. For example, 1 hour candle should start at 15:00 not from 15:15. How can I change it? Regards |
[2024-03-13 18:32:38] |
The start times of the bars is based on the Session Times you have set. Refer to the following: Chart Session Times: Bar Starting Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
