Date/Time: Thu, 06 Mar 2025 12:53:40 +0000
Erase trade activity data
View Count: 3426
[2014-08-09 00:11:51] |
User120827 - Posts: 77 |
Can you erase trade activity data from sim accounts and start over fresh ? thanks |
[2014-08-09 02:21:51] |
Yes. Refer to: https://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#ClearingtheLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-09 02:44:25] |
Thank you ! shane |
[2014-08-09 02:49:03] |
Can you delete data on just some of the sim accounts ? By using the edit trade activity entry window ? thanks shane |
[2014-08-09 04:24:19] |
You can delete data for any particular simulation account by selecting that simulation account from the list of accounts at the top of the Trade Activity Log window before selecting Edit>> Clear.
[2014-08-09 12:26:35] |
User021827 - Posts: 174 |
Thank you regards |
[2020-10-11 15:12:21] |
User103448 - Posts: 76 |
Is there a way to restore this?
