Date/Time: Mon, 25 Nov 2024 09:19:56 +0000
Camarilla pivot point(Formula type 5) S6 & R6 not plotting
View Count: 486
[2024-03-13 16:13:50] |
User763335 - Posts: 82 |
The study does show these levels and is enabled to print, but not plotting for any stock ticker.($AMD,$AAPL,$TSLA etc). Time period Type:Days, Time Period Length:1, Formula Type:5 Pls advise, |
[2024-03-13 17:31:49] |
There are no S6/R6 calculations for the Camarilla Pivot Points. You can see this in the definition of the calculations here: Pivot Points: Formula Type 5 (Camarilla Pivot Points) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-13 18:20:06] |
SierraChart doesnt have these, but other platforms do and I use them presently. Can we add these pls to SC .. Here's a reference from DasTrader Camarilla pivot point calculations including S6 & R6 https://dastrader.com/docs/how-to-view-the-pivot-point-indicator-on-the-chart/ Another reference: https://www.fxstreet.com/education/trading-stocks-with-camarilla-pivots-201211010000 and https://mtrading.com/education/articles/forex-strategy/camarilla-pivot-point-strategy-for-beginners Date Time Of Last Edit: 2024-03-13 18:50:27
[2024-03-14 12:40:27] |
pls advise.. this should be relatively easy to add..the study already has these levels defined ,just need to be enabled with correct formula. S6 = Close – (difference between R6 and Close) R6 = (High/Low) * Close S6 & R6 come into play on big trend days... Thanks! |
[2024-03-17 14:17:34] |
Not sure why is this so difficult? Can someone pls assist with a custom study to add these two levels, with formula provided, since SierraChart isnt willing to add these? Thanks! |
