Date/Time: Mon, 25 Nov 2024 08:51:58 +0000
Chart Windows Tiled Vertically Screenshot
View Count: 190
[2024-03-13 14:22:10]
TradeHax - Posts: 2
I have 3 chart windows tiled vertically on a single screen. Is there a way within sierra chart to screenshot? I can only get 1 window to capture. When I use a separate web clipper my crosshair is on the chart. I'd like to take screenshots without always having to change tools if possible. I attached an example of my screen and what I am trying to capture. I have read through the docs and didn't find an answer to this. Apologies if it's already been asked. Thank You
imageScreenshot 2024-03-13 101825.png / V - Attached On 2024-03-13 14:19:41 UTC - Size: 118.54 KB - 57 views
[2024-03-13 16:21:38]
Select "Edit >> Screen Images >> Save Main Window to File".
You can also setup a keyboard shortcut for this.
