Date/Time: Mon, 25 Nov 2024 08:33:21 +0000
number bar increments
View Count: 177
[2024-03-13 14:16:07] |
daniel kagan - Posts: 3 |
Hi team, I would appreciate your help regarding the number bar. I'm looking for the setting that changes the display of data in the number bar. Currently, it shows the bid and ask in one tick increments. I would like to change the data display within the number bar to increments of 4 ticks. Where can I find the setting for this? Thank you very much. |
Screenshot 2024-03-13 161437.png / V - Attached On 2024-03-13 14:15:19 UTC - Size: 95.63 KB - 50 views Attachment Deleted. |
[2024-03-13 16:18:36] |
Refer to the following: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
