Date/Time: Mon, 25 Nov 2024 08:34:12 +0000
Trading marks on a Chart is off
View Count: 210
[2024-03-13 13:26:42] |
User723587 - Posts: 3 |
Hello Support Team, what seems to be the issue? i have no idea why this is happening. *image attached* |
Chartsareofff.png / V - Attached On 2024-03-13 13:25:15 UTC - Size: 80.12 KB - 53 views Attachment Deleted. |
[2024-03-13 14:58:40] |
Sierra_Chart Engineering - Posts: 17172 |
We will write documentation for this. This is a continuous futures contract chart. You need to understand for each day in the chart, what contract month is it. Refer to: Continuous Futures Contract Charts: Displaying Rollover Transition Times and Contract Months Order fills are loaded for the current symbol of the chart. It is also possible to load order fills for prior contracts. On prior days, which are a different contract month, order fills for the current contract, will not match the price of the prior contract. This is normal. One solution to the problem is to use this option: Chart Settings: Load Order Fills for Multiple Futures Contracts (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-13 14:59:35
