Date/Time: Mon, 25 Nov 2024 08:23:02 +0000
indicator
View Count: 188
[2024-03-13 13:11:31] |
Boris Libman - Posts: 58 |
Wondering if there is an indicator that can run in a chart (in a separate pane) that color codes a bull/bear bias based on a reading from another indicator. For example if price above x moving average AND Y moving average, color code one color, if both criteria not met, color code a different color, etc.
[2024-03-13 15:46:00] |
Attached is a Study Collection that does what you are asking for. You can change the size of the subgraphs in the Spreadsheet Formulas to make the items taller or shorter in the area. We removed the display of the study information for the region, but you can turn it on if you want. Start with this collection and modify, or use it as a learning space, to get what you want. Refer to the following for how to use a template: Study Collections: Using a Study Collection Provided by Sierra Chart Support The one "trick" in setting this up is that you are expanding the scale in the region such that all the data lines up in a single line. To do this, you need to have at least two different values, which means turning on the option for "Show Zero Values" in a Spreadsheet Formula and then adjusting the scale, and then turning this option off again. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
ColorCodeBasedOnMovingAverages.StdyCollct - Attached On 2024-03-13 15:43:58 UTC - Size: 64.07 KB - 314 views |
