Date/Time: Mon, 25 Nov 2024 09:39:13 +0000
Forward Curve-Chart
View Count: 197
[2024-03-12 20:48:56]
User841161 - Posts: 221
I am charting the forward curve chart of Crude Oil(Term Structure). I am utiiizing the Forward Curve Study to do so. I was wondering if there way to plot each settlement price of each futures contract comprising the forward curve- maybe utilizying a circle on the chhart for each month.
Here is picture of the Foward Curve, https://www.sierrachart.com/image.php?Image=1710276171605.png.
[2024-03-12 22:00:02]
There is not a way to do this within the study itself, but you can use the "Study Subgraph Reference" study to do this for you. Add the Study Subgraph Reference and have it reference the Forward Curve study and make sure it is in the same region. Then set the "Draw Style" for the Study Subgraph Reference to "Point" or "Square" or some kind of marker to get it displayed that way.
If you set the Draw Style to "Value of Subgraph", then you will get the actual price displayed.
With whatever you display, you will need to update the Size so you can see it well.
Refer to the following:
Chart Studies: Point (ACSIL: DRAWSTYLE_POINT)
Chart Studies: Value of Subgraph (ACSIL: DRAWSTYLE_VALUE_OF_SUBGRAPH)
