Date/Time: Mon, 25 Nov 2024 08:22:53 +0000
Footprint chart customizations
View Count: 481
[2024-03-12 18:03:13]
User377189 - Posts: 172
On the numbers bars/footprint chart i am trying to achieve the following:
1) Single print boxes - In a footprint chart if single prints are printed i want a box around them. The color of box should be as the candle. red candle = red box and same for green
2) Ratios to be printed on top of red candle and bottom of green candle. Red candle the top two ask numbers are divided and for green candle bottom two bid numbers are divided to give ratio
3) Whenever stacked imbalances are formed i want a box with corresponding color of imbalance (selling = red ; buying imbalance = green). For this i used study-volume at price threshold alert V2. I do not get a box but i get a line. I cannot figure how to get the line to appear as box. Under settings i changed the extension line properties but still am not able to get a box like the screenshot
For above 3 customization's see attached screenshot for reference.
Private File
[2024-03-12 19:14:29]
1. We do not have a way to highlight Single Prints within the Numbers Bars study.
2. To print the ratios, you would need to use two copies of the Spreadsheet Formula. We have attached a Study Collection that does this for you. Refer to the following:
Study Collections: Using a Study Collection Provided by Sierra Chart Support
3. To get the "box" with the "Volume at Price Threshold Alert - V2" set the following Inputs:
- Highlight Adjacent Alerts Group Size: The number of levels for which you want to draw the "box".
- Draw Extension Lines: All Prices in Adjacent Alerts
- Draw Extension Lines with Transparent Range
Volume at Price Threshold Alert V2: Inputs
attachmentBidBottom_AskTop_VolumeRatios.StdyCollct - Attached On 2024-03-12 19:10:31 UTC - Size: 32.16 KB - 162 views
[2024-03-13 02:48:17]
1) For the single prints - in the numbers bars study is there a way to change text color only for single prints?
2) Thank you for the Ratios - Is there a way to highlight these per ratio. example - if i set ratio @ 0.699, indicate that extreme number is minimum twice as big as the next number
3) For the "Volume at Price Threshold Alert - V2" - thank you for reference to the documentation. I did manage to get the boxes for stacked imbalances
Date Time Of Last Edit: 2024-03-13 13:53:33
[2024-03-13 14:23:32]
1) We do not have a way to call out Single Prints in the Numbers Bars study.
2) If you only want it to display when it meets a certain criteria, then you would need to add this to the IF() statement in the Spreadsheet Formula.
If you want to "highlight" (have a different color, or size) when there is a certain criteria, then you would need to have another Spreadsheet Formula that has the criteria you want and sets the display as you want. You would then have to set the other Spreadsheet Formula to have the opposite condition so it is not shown.
