Date/Time: Mon, 25 Nov 2024 09:56:53 +0000
Nubers Bars- Show bar volume profile as percentage of overall visible bars volume?
View Count: 183
[2024-03-12 16:58:44]
funbun - Posts: 90
Currently, each bar's volume profile is using all the bar's width to show the VbP, regardless of the intensity of the bar's overall volume.
Is it possible to show a narrow/wide bar's VbP as a function to the bar's overall volume intensity?
Just like Volume based candlestick bars - The visible bar on the chart with the highest volume will have the widest VbP and so on...
That could be a very clean visual representation of the real "weight" of each VbP on the chart.
[2024-03-12 17:27:25]
Refer to the following Input for the Volume by Price:
Volume By Price Study: Volume Profile Bars Length Relative to All Visible Profiles
