Date/Time: Mon, 25 Nov 2024 09:28:04 +0000
Adding priceline to
View Count: 223
[2024-03-12 16:32:40] |
Optionyout - Posts: 7 |
I have added additional symbols to my main chart but can't add a priceline within the additional symbols. Is that possible?
[2024-03-12 17:20:38] |
Yes, this should not be an issue with this. Just make sure the "Current Price Line" study has the "Based On" set to the "Add Additional Symbol" study you want, and that the Region is set to match where that "Add Additional Symbol" is located. Refer to the following: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Chart Studies: Settings and Inputs Tab >> Chart Region For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
