Date/Time: Mon, 25 Nov 2024 09:27:42 +0000
Sever Connect Disconnected Alert Sound?
View Count: 281
[2024-03-12 14:30:59] |
AmberNinja - Posts: 31 |
I found the server connected disconnected sound settings. What are the sounds??? Why did you take away the test buttons so we can hear the sounds? Where is a list of all the sounds you have listed and what the say??? they are only numbered... I found an "Alert Sound" under the Sound File area and that actually has a test button and even a sound file in there that says disconnected and connected for some arbitrary sounds which makes NO sense. Any idea??? |
[2024-03-12 16:37:41] |
We did not take away the "Test Sound" button. It is still on the "General Settings >> Alerts" page, where you can select a sound file and then select the "Test Sound" button. Refer to the following: General Settings Window: Alert Sound File Name (Global Settings >> General Settings >> Alerts >> Sound File) All of the files that we provide are located in the "AlertSounds" folder under your main Sierra Chart installation folder. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-13 16:57:25] |
There is NO test button for ALL the other sounds! Only that one sound. How do we test all the 100 other sounds???
[2024-03-13 17:39:27] |
You select the sound you want to test in the field for "Alert Sound File Name" and then select the button for "Test Sound". You would have to cycle through the sounds to hear them all. You can also open them directly on your computer and use the Microsoft media player to play the sounds. They are just Wave files. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-17 16:01:39] |
Yea that doesnt work for the other 1-200 sounds files that are not named.. But i'm dealing with this in another ticket. I guess we can close this ticket and I will deal with it in the other ticket. Thanks.
