Date/Time: Tue, 22 Apr 2025 18:06:03 +0000
SetTradeWindowTextTag() and Trade Activity Log
View Count: 277
[2024-03-12 14:08:17] |
gtaranti - Posts: 94 |
When calling the function SetTradeWindowTextTag AFTER a position is open, does not have any effect to the 'Note' column of the Trade Activity Log (Trades window). I'd like to append Note column with information bits when opening a position AND before closing it (e.g. to document which exit signal has been triggered) As it is now, (v. 2604) you can only set the TextTag (Note column) before opening a position. I think it'd be helpful to enhance this functionality and populate Note column, AFTER the position closes (like for example the Exit Price). Thanks. Date Time Of Last Edit: 2024-03-12 14:35:46
[2024-03-14 10:03:31] |
Please Support, I need an answer on this. I use SetTradeWindowTextTag function to set information (comma seperated values) about the current trade , which in effect shows in the Note column of Trade Activity Log Why the Note column is updated only on the trade entry, and not in the trade exit also? If it's not in your plans to do something about it, please respond. Date Time Of Last Edit: 2024-03-14 10:04:52
[2024-03-14 16:00:39] |
John - SC Support - Posts: 39416 |
It is the way it functions today. We can not say when we would get around to making a change. We have noted this as a feature request.
[2025-01-07 19:55:42] |
Any plans to offer this feature? TextTag is, I believe, the only way to differentiate trades in the Activity Log according to some user defined criteria. The ability to change the tag at any stage of the trade would be very helpful. |
