Date/Time: Mon, 25 Nov 2024 09:28:54 +0000
Text Box that is fixed on screen (like the Clock Study)
View Count: 312
[2024-03-12 13:51:54]
countryboy92 - Posts: 91
I use the clock study on my chart and it stays in the same location on the screen (fixed) without moving as the chart changes throughout the day.
Is there a way to do that with a Text Box, so I can keep it in the right hand corner throughout the session?
[2024-03-12 13:52:36]
It sounds like what you want is the "Stationary Text" tool. Refer to the following:
Chart Drawing Tools: Type Text | Stationary Text
[2024-03-12 14:23:37]
DFromeaux - Posts: 10
Alternatively, if the text is not supposed to change (no variable or the result of another study), you can use the Symbol Display study by choosing a custom label !
