Date/Time: Mon, 25 Nov 2024 08:57:20 +0000
RTH and ETH different view size on chart
View Count: 333
[2024-03-12 12:22:38]
User937068 - Posts: 10
Hi
I need to split the chart into 2 and be able to modify the size independently between the new regions.
For example in the screenshot attached, i want to decrease the ETH portion and increase the RTH so that on the screen i will have the ETH displayed every 10 minutes and RTH minute by minute. ( or whatever )
Just because i am more interested in RTH but there are more hours for ETH so overall by default most of the screen will be occupied by ETH period.
Not sure how efficiently i described what i want but hopefully someone will understand.
imageUntitled.jpg / V - Attached On 2024-03-12 12:18:52 UTC - Size: 91.3 KB - 60 views
[2024-03-12 16:21:21]
We do not have support for what you are wanting to do.
[2024-03-13 07:15:41]
Hi John
Then maybe it's something else that i cannot explain.
I attach the situation where one part is displaying 17H and the other is showing just 7H but on a larger scale.
imageUntitled2.jpg / V - Attached On 2024-03-13 07:15:34 UTC - Size: 159.31 KB - 63 views
[2024-03-13 14:51:36]
Whatever caused this to occur is not related to having different scaling for the sessions. It is just due to having fewer bars in the overnight than in the day session. Some items that can cause this are the following:
- The Session Times do not cover the full hours for the overnight session.
- The lower trading volumes can mean that bars are not created for times of lower volume
- Volume-based, or range-based bars will not create as many bars due to the lower volume.
[2024-03-13 15:39:07]
Thanks John.
Then i will play with your list items maybe i get it.
This can be closed.
Thank you.
[2024-03-14 16:28:09]
If anyone else search for this it's Candlesticks based on Volume instead of Time. This makes sense only on specific markets.
