Date/Time: Mon, 25 Nov 2024 09:53:25 +0000
Rollover Chart Drawing Symbols - issue
View Count: 257
[2024-03-12 10:58:54] |
sampater - Posts: 244 |
Sierra Chart Engineering, I did a contract rollover. Despite the Also Rollover Chart Drawing Symbols option checked, the drawings were not moved. Thank you |
[2024-03-12 16:03:12] |
What do you mean by "they were not moved"? Do you mean that they are not showing in the chart with the new symbol, or do you mean that you did a back-adjusted continuous contract and the drawings did not move up/down with the back adjustment? For the former, you would need to update the symbol for the drawings by selecting "Chart >> Update Chart Drawings to Current Symbol". Refer to the following: Chart Menu: Update Chart Drawings to Current Symbol (Chart menu) For the latter, you would need to adjust the drawings manually. Refer to the Adjust option on the Manage Chart Drawings Window: Chart Drawing Tools: Manage Chart Drawings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
