Date/Time: Wed, 27 Nov 2024 07:28:11 +0000
Update manual text file
View Count: 1068
[2014-08-08 19:26:20] |
George - Posts: 60 |
The manually created text file displays the chart fine. Then when I add data to it via "edit data - historical chart", how do I update the chart?
[2014-08-08 22:49:27] |
Chart >> Reload and Recalculate.
[2014-08-09 15:08:21] |
The file is updated and saved, but the chart will not update. I tried chart>> reload and recalculate, but it will not update. It is Daily data, the Date format I am using is mm/dd/yy. I could not save the yyyy/mm/dd format from Excel in a .txt file. Kindly advise.
[2014-08-12 18:21:32] |
If you are editing a Historical Daily data file through Edit >> Edit Data-Historical Chart, once you close the editor window, the chart will automatically reload. If you do not see the new data, there must be something wrong with the formatting of the data. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_TextCSVDataFormat.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-12 20:01:34] |
Thanks for your reply. I believe the formatting is correct. I add data to the end of the file through the Edit>> Edit Data-Historical Chart, then I save the file, but the new date is not shown updated into the Date Range File, so I can never add more data to the end of the file?
[2014-08-13 08:39:04] |
If it is the proper format it should be automatically loaded, and if not there still must be something wrong with the format in some way that is not obvious. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
