Date/Time: Mon, 25 Nov 2024 09:49:13 +0000
Multiple Rolling TPO Profiles with Different End Times in 1 Chart
View Count: 218
[2024-03-11 19:53:24]
ButtTruffle - Posts: 5
Hi, so currently I'm using 5 different charts to show the different profiles of End time. Attached is the "One period of Fixed Time Length at End" setting enabled, with a 2d, 3d, 5d, 10d, 15d, and 20d profile. I wanted to ask if there is a possibility of a setting where you can have all these profiles in one chart? So it would be 6 seperate profiles in one chart. Also, an additional request would be if a setting could be added where the TPO value area changes based on the # of TPOs? So in the example attached, if I selected the number 3, then the value area would be the blue/red area. The request is based off of Auction Market Theory analysis by Donald L. Jones. Thanks a lot!
Private File
[2024-03-12 14:52:10]
There is not a way to have different period TPOs on a single chart.
With regards to changing the Value Area, you could create a custom study to do this. Refer to the following:
sc.SetChartStudyInputFloat()
List of Third Party Sierra Chart Study and System Programmers
