Date/Time: Mon, 25 Nov 2024 10:47:59 +0000
volume symbol need rollover
View Count: 215
[2024-03-11 13:57:29] |
batman_ - Posts: 190 |
https://www.sierrachart.com/image.php?Image=1710165371242.png Kindly advise how to automate update volume symbol need roller as per screen image. |
[2024-03-11 16:05:21] |
Sierra_Chart Engineering - Posts: 17172 |
You do have to manually perform the rollover. Refer to: Changing to a New Futures Contract Month Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
