Date/Time: Mon, 25 Nov 2024 10:57:44 +0000
No data in my dom form chart
View Count: 225
[2024-03-11 08:56:51]
User181796 - Posts: 1
When I try to open the trading dom form chart, there is no data appearing (as seen on the attached picture). Can you tell me if I need to do certain adjustments in the software to make the data visible or if I bought the wrong services package 5?
imageScreen Shot.jpg / V - Attached On 2024-03-11 08:51:11 UTC - Size: 339.36 KB - 60 views
[2024-03-11 19:09:33]
We assume that you are referring to the Market Depth data. We no longer have the market depth data for Binance due to issues with that data.
[2024-03-12 00:17:34]
Sierra_Chart Engineering - Posts: 17172
For market depth data for crypto currencies use the BitMex symbols.
