Date/Time: Mon, 25 Nov 2024 08:33:42 +0000
how do i get indian stock market data
View Count: 492
[2024-03-11 05:57:16] |
User619673 - Posts: 4 |
how do i get indian stock market data and will the data provide me footprints and depth of market for indian stocks. This option of sierra charts i have to buy to avail this facility
[2024-03-11 17:42:01] |
The Indian stock data is available through the Global Data Feeds India service. Refer to the following: Global Data Feeds (India) Data Service In order to connect to a data service (or trading service), you need to be on one of the "Integrated" packages. Refer to the following: Description of Service Packages and Pricing: Integrated Packages Refer to the following for how to add funds and select a package: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-12 17:03:02] |
Actually i have another doubt that will i be able to use depth of market and footprint charts if i use Global Data Feeds (India) Data Service becasue both the tools are very important for my funds strategy
[2024-03-12 17:35:23] |
You will be able to use the Numbers Bars (footprints) with the Global Data Feeds India. But it does not appear that they have the Market Depth. You would need to ask them to know for sure.
[2024-03-13 10:24:03] |
do you support indian brokers api for level 2 data. Some indian brokers such as zerodha,angle broking, Groww.
[2024-03-13 15:23:15] |
The only connectivity we have is for the Global Data Feeds.
