Date/Time: Mon, 25 Nov 2024 10:23:14 +0000
Common stop order without a target (scale in)
View Count: 183
[2024-03-11 02:22:07]
Steve Leon - Posts: 301
If I use an attached stop order without an associated target order and i am scaling into a position. is there a way for there to be a single common stop order that would represent the stope for the average price with all the positions at that price and in that stop order. could not find the answer in the documentation (only for OCO orders)
Thank you
[2024-03-11 17:38:09]
It does not matter if there is a Target or not, the Scaling In works the same way. So you will have a single Stop that will continue to add quantity if you are Scaling In.
