Date/Time: Mon, 25 Nov 2024 10:29:13 +0000
QuoteBoard for Live account on Denaly not updating DailyChange DailyChange% after upgrade.
View Count: 236
[2024-03-10 22:42:33]
Meklon - Posts: 219
Hello Support,
I just upgraded to version 2611 and my QuoteBoard does not show any data for DailyChange and DailyChange% - these fields are all zeroes.
Also, "Auto Rollover Futures Symbols" on QuoteBoard is enabled but symbols are not rolling over. Clicking on "Rollover Futures Symbols Now" takes no effect either - contracts are still stuck on March 2024 and not rolling over to June 2024.
Is there an issue with a QuoteBoard or Denali datafeed?
Date Time Of Last Edit: 2024-03-10 22:44:01
image2024-03-10_18-41-41.jpg / V - Attached On 2024-03-10 22:43:26 UTC - Size: 42.65 KB - 67 views
[2024-03-10 22:52:55]
Sierra_Chart Engineering - Posts: 17172
This means the CME MDP data feed did not transmit the settlement prices. Let's see if they come later on this evening.
This is out of our control. Nothing we can do.
[2024-03-10 23:21:05]
Meklon - Posts: 219
Understood, thank you for a prompt reply.
What about the Rollover issue? Is there a reason the Auto Rollover and Manual Roll Over on a QuoteBoard not working?
Date Time Of Last Edit: 2024-03-10 23:22:32
[2024-03-10 23:59:12]
This would mean, that it is not determined, that a rollover should take place for the symbols that are not changing.
