Date/Time: Mon, 25 Nov 2024 10:49:43 +0000
Disable Auto Trading(Read/Write) Column J28 does not work
View Count: 212
[2024-03-10 20:26:27]
aswade3451 - Posts: 19
I have tried multiple ways for my automated trading system to stop taking trades when reaching a profit or a loss- nothing I have tried seems to work. Specifically when using column J28 and it =1, auto trading continues. The current code I have in there is =OR((HJ3>500),(HJ3<-500)) With HJ equaling a study for closed PNL.
What am I doing wrong? Is there another way for my goal of disabling automated trading to work? I have even tried putting the code above into my entry columns and it bugs out every couple days with the Closed daily PNL being different from the actual closed daily PNL
[2024-03-11 17:20:43]
If you manually set that field to 1 does it disable automated trading?
[2024-03-12 03:02:40]
No it does not
[2024-03-12 05:37:19]
Sierra_Chart Engineering - Posts: 17172
We do not observe any problem with that cell. It does disable automated trading. See below.
What is the Sheet number in the Spreadsheet, that cell is located on?
How is this input set?:
Spreadsheet Study Inputs: Formula Source Sheet Number
Spreadsheet Study Inputs: Use Column I and J Values Version 2
You should get this message:
2024-03-12 01:29:17.939 | Unset | Auto-trade: GCJ24-COMEX[M] 1 Min #2 | 2024-03-11 | Spreadsheet order signal has been ignored because Auto Trading has been disabled (Cell J28/J85).
