Date/Time: Wed, 27 Nov 2024 06:36:47 +0000
[User Discussion] - Total TTCK-NYSE plus TTCK-NASDAQ per bar ??
View Count: 1143
[2014-08-08 16:37:24] |
User27189 - Posts: 26 |
I'll re-ask the question in a more specific form. Can I create a simple bar chart of TTCK-NYSE+TTCK-NASDAQ? Thank you.
[2014-08-08 19:16:55] |
Sawtooth - Posts: 4120 |
Use the Sum study.
[2014-08-09 03:04:16] |
Thank you, "tomgilb" but I am an older, non-tech proficient trader/user. I do not know how to "use" the Study and I can find only the description of said Study in Support, but no instructions which I would gladly follow. In my old eSignal it was simple to do this. I simply typed in "$tick+$tickq"...pretty simple...huh? Bar chart appeared immediately. Can you help me, since the SC Engineering does not seem to be interested in my request after repeated requests..Thank you.
[2014-08-09 04:41:00] |
The Sum study will plot bars made from individual sums of the OHLC of two charts. You'll need two charts, one of the TTCK-NYSE and one of the TTCK-NASDAQ. -With one of the charts focused, go to Analysis >> Studies and scroll down to the Sum study, click the Add >> button. -Click on Settings and set the Chart 2 Number to the other chart. -The summed bars will appear in a region below the main price graph. If you want the summed bars displayed as the main price graph, check 'Display As Main Price Graph'. |
[2014-08-09 20:42:18] |
Many thanks, "tomgilb". That appears to work.
Date Time Of Last Edit: 2014-08-09 21:36:07
