Date/Time: Mon, 25 Nov 2024 09:58:15 +0000
Laggy Chart.
View Count: 338
[2024-03-09 18:56:30] |
Tin43 - Posts: 90 |
Symbol: Emini ESH24 Days to load: 365 Days Evening Session: NO Continuos Contract: Volume Based Rollover Back Adjusted Studies on Chart: Volume By Price, based on volume. Multiple Profiles Based on Fixed Time (Days) Using the chart in the 1 Minute TF and in the 5 Minutes, everything ok. Moving to 1H or 4H, impossible. Lagging interface. Moving the chart takes like 3 seconds if it moves. (Sometimes not). Sometimes even buttons interface freeze if I click on many places in the chart or move the chart and then clicking on them. Cpu Usage: 11% Memory Usage: 34 Disk Space Available: 60GB of 250GB. Don't understand what is happening. Seems everything ok in my pc. There is something I can do to improve performance? I got an I5 10400F and a AMD 78000XT 16GB. NVME 3.0 gen. 16GB Ram. Thanks in advance. Edit: I found the problem. Hidding the Volume by Price study improves performance to normal. So now the question is... what DO I NEED (in hardware I suppose), to avoid the laggy effect? Better processor, more ram, more disk.. what? I need to replay chart with those volumes. Date Time Of Last Edit: 2024-03-09 19:02:21
[2024-03-09 21:15:13] |
Sierra_Chart Engineering - Posts: 17172 |
Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.34 - TPO Profile Chart Letter/Block Price Increment / Volume by Price Ticks Per Volume Bar Let us know if that helps. Also refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-09 21:15:39
[2024-03-16 10:01:24] |
Tin43 - Posts: 90 |
Thanks!
