Date/Time: Tue, 26 Nov 2024 06:34:09 +0000
VPOC Shift Alert
View Count: 1641
[2014-08-08 16:34:49]
OneMoreTick - Posts: 79
How would I code an alert to trigger when the POC shifts in the Volume Value Area Lines study. I want it to trigger for any shift at all, up or down. I know the general syntax (For Ex: ID1.SG1 > 1900) for alerts but I don't know what to reference to make this alert. Is there a last value or something like that for the POC to reference?
[2014-08-08 16:39:47]
It sounds like you want to reference the prior value of the point of control study Subgraph. Use this to reference the prior value:
ID1.SG1[-1]
[2014-08-08 16:44:38]
So to trigger if prior value is greater or less than current value, would it be 1 or 2?
(1) =ID1.SG1[-1] <> ID1.SG1[1]
(2) =ID1.SG1[-1] <> ID1.SG1[0]
[2014-08-08 22:30:42]
Formula 1 does not make sense.
2 should be what you want.
[2023-12-21 12:07:42]
tokauo - Posts: 32
Can not get to work VPOC Shift Alert, with any above, is it still available function in 2023?
[2023-12-21 16:21:25]
John - SC Support - Posts: 36286
Are you using the "Volume Value Area Lines" study and did you change the ID to be the ID of your study?
Refer to the following:
Study/Chart Alerts And Scanning: Referencing Other Studies on the Chart
[2023-12-21 16:24:10]
tokauo - Posts: 32
I had to activate Developing POC and to use
=ID1.SG2[-1] <> ID1.SG2[0]
and it is working. Thanks you
[2023-12-21 17:16:27]
SG2 of the Volume Value Area Lines is the "Value Area High". If that is what you are wanting to test, then that is fine. We just want you to be aware.
[2023-12-21 17:26:36]
tokauo - Posts: 32
Ooops. I'm sorry I have overlooked that original question is about Volume Value Area Lines. I was looking for solution for Volume By Price, but it works anyway .-)
Thanks you
