Date/Time: Mon, 25 Nov 2024 10:48:23 +0000
Flatten & Cancel @ Set Time setting
View Count: 183
[2024-03-09 12:47:34] |
User194332 - Posts: 40 |
Hi I have the flatten & cancel at set time setting on the DOM but notice that I am still in a position. Is there any reason why this would not exit a position (see attached). Regards Avi |
[2024-03-11 15:54:00] |
There is nothing attached. Most likely it is that the position is for a different chart, or the Trade Window is for a different chart. Refer to the following: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
