Date/Time: Mon, 25 Nov 2024 10:35:47 +0000
Connection error: No trade accounts assigned
View Count: 326
[2024-03-08 20:45:38] |
monk - Posts: 13 |
I have an active, funded trading account using AMP Futures and SierraChart. Today I attempted to switch over to Teton Order Routing. I went to Global settings - data trade service settings and selected TETON CME ORDER ROUTING. For the Clearing firm list I selected AMP. Hit Apply All and OK. Now the following message appears... Connection error message from service: Teton CME Order Routing Connection error: No trade accounts assigned What else do I need to do? Thank you. -Al |
[2024-03-08 21:09:08] |
Refer to the following: Sierra Chart Teton Futures Order Routing: Common Mistakes Also be aware that if your broker has not finished the setup, then you will also get that message, so make sure they have completed their work first. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
