Date/Time: Mon, 25 Nov 2024 10:22:13 +0000
Scrollung a Chart
View Count: 170
[2024-03-08 19:06:21] |
User360283 - Posts: 504 |
Currently when the price gets near the top or bottom of my Renko charts I want to move the chart up or down. But this insanely difficult. Please create a Scroll up and down mechanism simian to the Standalone DOM by pressing and holding down the chart scale. Thanks |
[2024-03-08 20:54:39] |
The Chart DOM and the Trading DOM work exactly the same. So if you are not able to move the chart scale in the same way as the Trading DOM then it is a setup difference in your system. In particular, right click on the Chart DOM price ladder and note the setting for the "Interactive Scale" options at the top of the list. If you want to be able to move the ladder up/down with just a left click, then make sure the option for "Interactive Scale Move" is the one that has the checkmark (select it). Refer to the following: Chart Scale and Scale Adjusting: Interactive Scaling For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
