Date/Time: Wed, 27 Nov 2024 06:27:18 +0000
TRIN Formula & Calculation Method?
View Count: 1975
[2014-08-08 16:14:29] |
User93103 - Posts: 48 |
Hello: Which one of these equations are used by Sierra Charts in order to calculate TRIN? ((Advancing issues - declining issues) / (advancing volume - declining volume)) or, (advances / declines) / (up volume / down volume. Thank you. God Bless Ben |
[2014-08-08 17:25:39] |
The formula is documented on this page: http://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-08 19:23:51] |
Hello: Base on the equation provided by Sierra Charts,is a negative value for TRIN mathematically possible? I need to study more. God Bless Thank you Ben |
[2014-08-09 00:14:53] |
All we can say is that we do not see this market statistic go negative.
