Date/Time: Fri, 28 Feb 2025 01:57:50 +0000
Odreders - Change Background Colors
View Count: 203
[2024-03-08 13:43:15]
User360283 - Posts: 510
I have sever vision impairment and cannot see orders with Red background.
Please provide the SPECIFIC location for changing the Order Background Color
[2024-03-08 15:49:22]
John - SC Support - Posts: 38259
You need to select the "Graphics Settings" and find the entry for the following:
- Chart Trading Position Line Short/Loss
and change the color for this. Refer to the following for this particular coloring option:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trading Position Line Short/Loss
But, you also may want to change the colors for other items such as the working orders. Refer to the Graphics Settings starting at the following:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trading Orders Being Inputted
And go down through each of the items and change the ones you need in the Graphics Settings.
Note that we can not give absolutely specific instructions, as we do not know if you are using Global Graphics Settings or Chart Specific Graphics Settings, which will determine which graphics settings window you choose.
To get to the Global Graphics Settings, select "Global Settings >> Graphics Settings - Global" and then scroll down to find the entries you are looking for. The order they are in on the documentation page is the order in the settings, just be aware that the links we gave are only for the trading related settings, so you will see other items on the page as well.
