Date/Time: Mon, 25 Nov 2024 10:54:05 +0000
Two data feeds
View Count: 363
[2024-03-08 12:27:52] |
User472677 - Posts: 350 |
I would like to use Denali for stock data but use Ib for futures and indexes. How do I accomplish this?
[2024-03-08 15:41:38] |
Any real-time data that you have activated with us will come from us, other data comes from your trading/data provider. So you would activate the stock data from our Denali Exchange Data Feed only, then this data would come from us, and other data, such as Futures, would come from Interactive Brokers. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services With regards to stock data from us, be aware that we have 3 options: 1. NASDAQ TotalView: Has the price and volume data only from the NASDAQ exchange, but also has market depth data. Enter the symbol with a -NQTV suffix (e.g. IBM-NQTV) 2. U.S. Equities Consolidated Tape: Has the price and volume data from all U.S. exchanges where an instrument trades, but does not have market depth data. Enter the standard symbol (e.g. IBM). 3. U.S. Equities Consolidated Tape with NASDAQ TotalView: If you active both, then you can get the combined data of the price and volume from the U.S. Equities Consolidated Tape with the Market Depth from the NASDAQ Total View. Enter the symbol with an _MBO suffix (e.g. IBM_MBO). Refer to the following for more information on these: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Denali Exchange Data Feed: US Equities Consolidated Tape Data Feed Notes -- To set the data, follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-08 21:12:15] |
Please help clarify. To receive data on stocks from Denali and data on futures from Interactive Btokers, will I set DATA/TRADE SERVICE SETTING to SC DATA or to Interactive Brokers?
[2024-03-11 02:46:18] |
Please reply.
[2024-03-11 03:54:40] |
Sierra_Chart Engineering - Posts: 17172 |
Do you plan to do any trading from Sierra Chart? If not, we would definitely recommend not setting Sierra Chart to use Interactive Brokers.
[2024-03-11 11:52:40] |
i do want futures data from interactive brokers and stock data from Denali. How do I do this?
[2024-03-11 16:09:06] |
For stock data from the Denali Data Feed, use a separate installation of Sierra Chart: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
