Date/Time: Mon, 25 Nov 2024 10:24:17 +0000
Color Based on Alert Condition - Wrong Bar
View Count: 275
[2024-03-08 11:43:00] |
jrob - Posts: 22 |
Hello, I am using the Color Bar Based on Alert Condition to alert based off of the Calc Values volume / sec. It is working however the alert is displaying on the bar AFTER the alert condition. I am using full precision. I have attached an image. Based on the alert conditions, the text should be on the first two bars and not the 2nd and 3rd. Any suggestions? |
[2024-03-08 15:19:22] |
The image did not capture the window you were trying to get, so we do not know how you have this setup.
[2024-03-10 01:03:31] |
jrob - Posts: 22 |
I have uploaded a new image. Here is the alert condition =ID6.SG36>100
You can see it is printing on the next bar vs the actual bar with the condition. |
Private File |
[2024-03-11 16:34:29] |
Please get us that chart by following these instructions and we'll take a look: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-11 18:40:50] |
jrob - Posts: 22 |
Chartbook has been attached.
[2024-03-11 19:08:32] |
You have a Displacement for that subgraph set to 1. Therefore it is offset by 1 bar. Change the displacement to 0. Refer to the following: Chart Studies: Subgraphs Tab >> Displacement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-11 19:21:39] |
jrob - Posts: 22 |
Ugh....thank you so much. I am not sure how that got there. Easy fix, sorry for the trouble.
