Date/Time: Mon, 21 Apr 2025 04:50:13 +0000
Chart Values/Crosshair Tool
View Count: 293
[2024-03-08 10:53:53] |
JVincent - Posts: 24 |
Greetings...I noticed after upgrading to version 2609 that the data window at the bottom of the vertical crosshair is blank, no longer displaying the bar initiation time.
[2024-03-08 15:10:08] |
John - SC Support - Posts: 39362 |
There is a new setting for the color of the text in the boxes. Refer to the following: Graphics Settings: Chart Values: Price and Time Boxes Text Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-08 15:40:20] |
Greetings...I went to the 'Chart Values' tab per instructions above...there is nothing there to change the color of the data window fonts in version 2610.
[2024-03-08 17:08:28] |
We have no idea what window you were dealing with, as we do not know what the "Chart Values" tab is. This is in the "Colors and Widths" tab of the Graphics Settings, either accessed through "Global Settings >> Graphics Settings" or "Chart >> Graphics Settings" depending on whether you are using Global or Chart specific graphics settings. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-06 17:39:48] |
ROI+ - Posts: 10 |
I see no data other than the ending time of the bar on which I place the crosshair. How do I get the chart to show data related to price and data related to the studies?
[2025-03-06 19:17:01] |
Refer to the following: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
