Date/Time: Wed, 27 Nov 2024 06:28:10 +0000
Question regarding using Sierra chart Real time.
View Count: 913
[2014-08-08 13:59:06] |
User48557 - Posts: 138 |
I'm currently set up with Real time Sierra chart usage for the VIX and the s&p Indices.I noticed the prices refresh every 15 Seconds. Is there a setting where i can minimize that time to maybe 5 seconds?
[2014-08-08 17:22:10] |
Whenever the symbol trades, you will see an immediate update. So the frequency depends upon the symbol. Make sure Global Settings >> General Settings >> Chart Update Interval is set to 1000 ms or less. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
