Date/Time: Mon, 25 Nov 2024 11:46:52 +0000
horizontal line value
View Count: 273
[2024-03-07 20:50:02] |
User558455 - Posts: 70 |
Hello, With all the updates, I can not find the options to turn on anchor value when putting horizonal line. The chart line properties has everything but " Show value" or show anchor value The guide is no use as it still has old menu. Seem like user error (me) so please let me know how to enable the value of the line on the drawing for horizonal line (or other drawing) thank you as always. |
[2024-03-07 20:54:54] |
Please update to the latest release, as there have been multiple fixes to get everything working for these windows. Refer to the following for how to update: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-07 21:20:04] |
thank you for the prompt support John Will do! |
