Date/Time: Mon, 25 Nov 2024 11:35:15 +0000
Only one market is lagging
View Count: 189
[2024-03-07 19:50:54] |
User612988 - Posts: 3 |
Hello I am here with a question about lagging ESH4 market. I am using rithmic with denali data. I am trading two markets ES and CL both are seted up exactly the same on two different chartbooks with same indicators etc. The CL is working perfectly fine with the set up but ES is really lagging. I haven't had this problem before. Could this be because of more contracts traded in ES market? Thanks, Domas |
[2024-03-07 20:19:08] |
It definitely could be. And this can have an effect on the studies you are using as well, depending on what they do. Refer to the following for all the things you can do to improve performance: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
