Date/Time: Mon, 25 Nov 2024 07:00:55 +0000
Compact Tool Value
View Count: 365
[2024-03-07 18:23:46]
User68127 - Posts: 23
hello
Compact Tool Value function no longer works on Sierra Chart
When I select Chart value, the small window is no longer displayed
(Compact Tool value being well selected)
[2024-03-07 18:25:02]
Select "Chart >> Reset Child Windows". This should make the Compact Tool Values Window visible again.
[2024-03-08 11:42:40]
No, it doesn't work
[2024-03-08 15:16:03]
Are your crosshairs displayed? Have you left clicked on the chart to turn on/off the display of the Crosshairs/Tool Values Window?
[2024-03-11 08:12:20]
Yes, my crosshair is displayed
Yes, I clicked on the chart
Compact tool values is also selected
But it doesn't show
(no problem on the other hand with Tool value)
I also have another problem concerning the different prices which are not displayed (to the right of the chart) for all the Forex symbols (EURUSD etc...)
Everything is normal for indices but nothing on Forex
[2024-03-11 16:04:25]
Sierra_Chart Engineering - Posts: 17172
Refer to:
Chart Drawing Tools: Compact Tool Values Window Not Visible
[2024-03-14 08:35:12]
ok, compact tools values is back
But, I also have another problem concerning the different prices which are not displayed (to the right of the chart) for all the Forex symbols (EURUSD etc...)
[2024-03-14 10:06:23]
Provide an image of the chart or Trade DOM, by following these *exact* instructions:
Date Time Of Last Edit: 2024-03-14 10:06:55
[2024-03-18 08:59:45]
https://www.sierrachart.com/image.php?Image=1710752020870.png
Chart EUR/USD
the price scale is not visible
I don't have this problem if I display for example an index (DAX, SP500 etc...)
[2024-03-18 16:14:11]
If "Trade >> Trading Chart DOM On" is enabled (has a checkmark next to it), then check the color of the following Graphics Setting:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Values Scale Text
Otherwise, check the color of the following Graphics Setting:
Graphics Settings: Chart Values Scale Text Color
And make sure that you are changing the color in the appropriate location (Global or Chart graphics settings). Refer to the following:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
[2024-03-19 09:31:54]
Nothing works in what you are proposing!
I repeat to you that the absence of a price scale is only invisible on the values of Forex FXCM
Everything is normal on FXCM CFDs or Futures
[2024-03-19 14:59:24]
Please get us that chart by following these instructions:
