Date/Time: Mon, 25 Nov 2024 11:45:29 +0000
Numbers bar calculated value
View Count: 279
[2024-03-07 18:13:25] |
User377189 - Posts: 172 |
In the study settings:Numbers bar calculated value, how can i show Ask Volume Bid Volume difference percent as whole percent? Currently this shows 7% as 0.07
[2024-03-07 18:19:05] |
On the "Numbers Bars Calculated Values" study change the Input for "Display Percent Values as Decimal or Percentage" to "Percentage". Refer to the following: Numbers Bars: Numbers Bars Calculated Values Input Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
