Date/Time: Mon, 25 Nov 2024 11:39:11 +0000
Chart Trading Order Fills- Text Color not working
View Count: 232
[2024-03-07 18:09:25]
User490060 - Posts: 2
Hi guys!
I would like to change the color in the box of the filled trades and in addition the text size.
I changed the color from black to white in " Global Settings- Graphics Settings- Chart Trading Order Fills-Text Color" but it has no effect.
The text in the boxes are still black and unfortunately also the text size has no effect , too.
I am using the actual version 2610 - maybe I made something wrong.
Thanks René
imageSC_3.PNG / V - Attached On 2024-03-07 17:50:29 UTC - Size: 83.4 KB - 65 views
[2024-03-07 18:16:25]
That is the correct item to be changing for the text color in the Order Fills.
Since that is not changing the color, then this would mean that the chart is setup to use chart specific graphics, rather than the global. Select "Chart >> Graphics Settings - Chart" and see if the option at the top for "Use Global Graphics Settings Rather than These Settings" has a checkmark next to it. If it does not, then you need to make the change to that color in this window and not the Global Graphics window.
Refer to the following:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
[2024-03-07 18:55:16]
Thank you John, for your fast reply and perfect answer.
