Date/Time: Mon, 25 Nov 2024 10:38:10 +0000
nasdaq total view vs. us equities consolidated tape
View Count: 368
[2024-03-07 17:45:08]
User626446 - Posts: 2
i am a service package 11 member and i activated the nasdaq total view and also the us equities consolidated tape. now that both are activated i am looking to compare data. how do i look up a symbol for each exchange so i can comapre data? for example i like to trade the symbol SPY so how would i look up data for SPY in the nasdaq totalview and how would i find data for us equities consolidated tape?
also if its possible i would like to combine the nasdaq totalview and us equities consolidated tape data. how can i get combined data?
thank you
[2024-03-07 18:09:39]
To get data from the NASDAQ TotalView, you need to append -NQTV to the standard symbol (e.g. IBM-NQTV).
To get data from the U.S. Equities Consolidated Tape, you need to use the standard symbol alone (e.g. IBM).
And to get the combined data, which is the price and volumes from the U.S. Equities Consolidated Tape with the Market Depth data from the NASDAQ TotalView, you need to append _MBO to the standard symbol (e.g. IBM_MBO).
Refer to the following:
Denali Exchange Data Feed: US Equities Consolidated Tape Data Feed Notes
Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes
[2024-03-08 03:37:05]
User760939 - Posts: 1
hi , I got both consolidated tape and total view package with service package 11, how do i see the MBO at each level for us equities. thanks
[2024-03-08 14:52:15]
Market By Order Data: Step-by-Step Instructions
And make sure you open the symbol wit the _MBO suffix (e.g. IBM_MBO).
[2024-03-08 16:28:37]
Sierra_Chart Engineering - Posts: 17172
You can also use NASDAQ TotalView symbols:
For Market by Order data.
