Date/Time: Mon, 25 Nov 2024 11:49:38 +0000
Continues futures historical data
View Count: 191
[2024-03-07 17:24:49] |
Khaleddahrouj303 - Posts: 4 |
Hello, is their anyway that i can use continuous futures contracts while using rithmic data? Because im only able to get live data feed no historical and it gives me permission denied and loads the charts with only one bar for the live price. Is their any other way other than opening a broker account with stage 5 brokerage or is it the only solution? Best Regads! Date Time Of Last Edit: 2024-03-07 17:25:25
[2024-03-07 18:05:07] |
You can have Continuous Futures Contracts with Rithmic data, but the problem is that Rithmic does not provide any historical data for previous contracts. So the only way this works with their data is if you have already captured the previous contract data on your system (i.e. you have downloaded it when it was live data). The best solution is to use our Denali Exchange Data Feed instead. There is the requirement that you have a live, funded, futures trading account in order to qualify for the non-professional exchange fees from the CME Group. And you need to be able to connect to that account at least once a month. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have an account that qualifies for the above, then we recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
