Date/Time: Mon, 25 Nov 2024 11:49:29 +0000
SOXX SPLIT how to adjust
View Count: 300
[2024-03-07 14:27:11] |
VolTrader73 - Posts: 136 |
Hello the US ETF SOXX has done a 1 to 3 share split Charts and their indicators are rendered useless. Please advise how to fix |
[2024-03-07 21:04:20] |
Sierra_Chart Engineering - Posts: 17172 |
This symbol will be adjusted tonight around 9 PM Eastern time. At that time you will need to re-download the data. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download" from the main Sierra Chart menu. You just need to do this once per symbol and not for each chart. This command is on the main Sierra Chart menu at the top. Only use it from that location. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
