Date/Time: Mon, 25 Nov 2024 10:23:06 +0000
How can I make a saved set of studies to be loaded by default?
View Count: 187
[2024-03-07 13:28:30] |
RuBYGlyPh - Posts: 8 |
When I load a new intraday chart, it is a clean chart. I want it to open with a specific template of studies that I use, so I don't have to go to the studies tab every time I open a new session. How can I do this? |
[2024-03-07 16:25:08] |
Refer to the following: Using Chart Templates For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
