Date/Time: Mon, 25 Nov 2024 11:30:49 +0000
Slow download/install
View Count: 220
[2024-03-07 13:13:01]
User512353 - Posts: 42
Up to SC v2598 on 2024/02/07 the update via the application login window took about 1:30 minutes.
Starting with SC v2602 on 2024/02/15 the update took about 7 minutes.
Starting with SC v2609 on 2024/03/01 the update takes about 15 minutes. This was also observed today with SC v2610.
Note that also the download of the installer and zip-file from sierrachart.com is very slow (about 50kB/s).
This is not a local connectivity/bandwidth problem, because
a) the computer is connected via a 2Gb/s optical fiber
b) no other application experiences any such problems
c) ping to sierrachart.com is normal at 174ms:
64 bytes from sierrachart.com (38.142.170.158): icmp_seq=6 ttl=50 time=174 ms
Are you aware of any server-side problems?
Any suggestions how to further debug this problem?
First hint: The traceroute has some problems to get through:
traceroute to sierrachart.com (38.142.170.158), 30 hops max, 60 byte packets
1 sagemcom (192.168.1.1) 2.158 ms 2.225 ms 2.311 ms
2 lo1.bsr3-kobanya.net.telekom.hu (145.236.238.140) 5.664 ms 5.643 ms 5.623 ms
3 81.183.246.7 (81.183.246.7) 5.687 ms tge0-1-0-2.er1-szeged.net.telekom.hu (84.1.80.6) 5.667 ms 84.1.67.138 (84.1.67.138) 5.563 ms
4 81.183.0.37 (81.183.0.37) 5.543 ms 81.183.3.38 (81.183.3.38) 5.523 ms 81.183.0.37 (81.183.0.37) 5.503 ms
5 vie-sb5-i.VIE.AT.NET.DTAG.DE (217.239.40.149) 9.092 ms 9.063 ms 9.039 ms
6 vie-sb5-i.VIE.AT.NET.DTAG.DE (217.239.40.149) 10.994 ms * *
7 be3462.ccr22.muc03.atlas.cogentco.com (154.54.59.182) 13.603 ms * 13.549 ms
8 be3462.ccr22.muc03.atlas.cogentco.com (154.54.59.182) 13.529 ms be2960.ccr42.fra03.atlas.cogentco.com (154.54.36.253) 19.475 ms 19.456 ms
9 be2800.ccr42.par01.atlas.cogentco.com (154.54.58.238) 29.463 ms 29.444 ms 29.424 ms
10 be2800.ccr42.par01.atlas.cogentco.com (154.54.58.238) 29.405 ms be3111.ccr42.dca01.atlas.cogentco.com (154.54.89.225) 203.300 ms 203.244 ms
11 be2113.ccr42.atl01.atlas.cogentco.com (154.54.24.222) 203.213 ms be3111.ccr42.dca01.atlas.cogentco.com (154.54.89.225) 203.183 ms be2113.ccr42.atl01.atlas.cogentco.com (154.54.24.222) 203.154 ms
12 be2690.ccr42.iah01.atlas.cogentco.com (154.54.28.130) 139.533 ms 139.477 ms 139.445 ms
13 be2690.ccr42.iah01.atlas.cogentco.com (154.54.28.130) 139.416 ms be3851.ccr22.elp02.atlas.cogentco.com (154.54.2.6) 155.411 ms 155.383 ms
14 be3872.ccr32.phx01.atlas.cogentco.com (154.54.26.53) 167.355 ms 167.327 ms 167.301 ms
15 be3872.ccr32.phx01.atlas.cogentco.com (154.54.26.53) 167.272 ms be2696.rcr21.las02.atlas.cogentco.com (154.54.3.198) 175.399 ms 173.896 ms
16 be2062.nr01.b023602-1.las02.atlas.cogentco.com (154.24.70.233) 169.868 ms 169.833 ms be2696.rcr21.las02.atlas.cogentco.com (154.54.3.198) 173.776 ms
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
Private File
Private File
[2024-03-07 16:15:59]
You are having a network issue to our servers for the update. We can not say where it is, but there is something about your Internet routing that is causing you some issues with this particular item. There is nothing we can do about this, it is a public Internet issue that is beyond our control.
[2024-03-07 16:41:47]
OK, I will contact the Internet provider for this issue.
Does the SC application integrated downloader/updater also use the sierrachart.com (38.142.170.158) server for download or do we need to check a different server for that? If yes, please specify the server. Thanks!
[2024-03-07 20:09:05]
Sierra_Chart Engineering - Posts: 17172
Yes it is www.SierraChart.com.
[2024-03-07 22:17:58]
We have improved performance, of downloading Sierra Chart installation files. They have been moved to a higher performance server.
