Date/Time: Mon, 25 Nov 2024 10:48:18 +0000
Whats wrong with this two chartbooks?
View Count: 193
[2024-03-07 01:23:10] |
Sivle - Posts: 53 |
I have two chartbooks and i am interested in footprint and marketprofile letters and blocks. But when i load them up in sierra they dont show anything. Can somebody help and fix it so that the chartbooks show working footprint and working marketprofile with letters and blocks The symbol i want to use is E-mini S&P500. I would appreciate it. I will upload the two chartbooks. Date Time Of Last Edit: 2024-03-07 01:24:52
convertedG7FXPROFOOTPRINTCHARTBOOK-200409-002540.Cht - Attached On 2024-03-07 01:22:34 UTC - Size: 18.38 KB - 143 views convertedG7FXSTAGE1PROFILECHARTBOOK-200608-010449.Cht - Attached On 2024-03-07 01:22:59 UTC - Size: 37.21 KB - 241 views |
[2024-03-07 01:56:14] |
cmet - Posts: 551 |
Check your symbols. Make sure they're correct for your data service provider.
[2024-03-07 15:46:29] |
As cmet states, most likely is is symbols. Open the Chartbooks and select "Edit >> Translate Symbols to Current Service" to update the symbols for your service.
