Date/Time: Mon, 25 Nov 2024 10:46:34 +0000
[Programming Help] - ACSIL UseTool - How to toggle Text on a line to its endpoint
View Count: 202
[2024-03-06 23:10:49]
User43 - Posts: 101
[Repost since in my original post the Title did not come through as expected]
Can anyone please advise on how to toggle "Draw Text At End" for a drawn line via ACSIL.
see attached pic for reference.
Looking through the tools structure I found
ShowLabelsAtEnd
but that setting is not documented and did not work as expected.
here my test code so far:
SCSFExport scsf_UseToolExampleLine(SCStudyInterfaceRef sc) {
// Set configuration variables
SCInputRef Input_Pos = sc.Input[0];
SCInputRef Input_UserDwg = sc.Input[1];
if (sc.SetDefaults){
sc.GraphName = "UseTool Example: Line";
sc.GraphRegion = 0;
sc.FreeDLL = 0;
sc.AutoLoop = 0; // No automatic looping
Input_Pos.Name = "Position";
Input_Pos.SetInt(-1);
Input_UserDwg.Name = "User drawing";
Input_UserDwg.SetInt(-1);
return;
int &LineNumber = sc.GetPersistentInt(1);
if (sc.IsFullRecalculation) {
// Draw vertical line on prior bar during full recalculation.
s_UseTool Tool;
Tool.Clear();
Tool.ChartNumber = sc.ChartNumber;
// Tool.LineNumber will be automatically set. No need to set this.
Tool.DrawingType = DRAWING_LINE;
Tool.AddAsUserDrawnDrawing = Input_UserDwg.GetInt();
int DrawingIndex = sc.ArraySize - 4;
Tool.BeginDateTime = sc.BaseDateTimeIn[DrawingIndex - 10];
Tool.EndDateTime = sc.BaseDateTimeIn[DrawingIndex];
Tool.BeginValue = sc.Low[DrawingIndex - 10];
Tool.EndValue = sc.High[DrawingIndex];
Tool.Text = "Label 1";
Tool.TextAlignment = DT_BOTTOM | DT_LEFT;
Tool.ShowLabelsAtEnd = Input_Pos.GetInt();
Tool.VerticalText = 1;
Tool.Region = 0;
Tool.Color = RGB(255, 255, 0);
Tool.LineWidth = 5;
Tool.AddMethod = UTAM_ADD_ALWAYS;
sc.UseTool(Tool);
LineNumber = Tool.LineNumber;
imageSierraChart_64_OX7MA8woJz.png / V - Attached On 2024-03-06 23:09:26 UTC - Size: 15.52 KB - 57 views
